Need help. My gimbal continues to move up even at low gimbal speeds and 25 smoothness. Already calibrated the compass and gimbal. No joy.
It's the smoothness setting, not a failure in the control wheel.Mine does this sometimes, it's the controller wheel not returning to a neutral position when released. Try rotating the wheel up and down a few times before takeoff. If that doesn't fix it, just learn to manually rotate the wheel to a neutral position.
What smoothness settings do you use?It's the smoothness setting, not a failure in the control wheel.
I switch to Cine mode for almost all video and photos. I slow the yaw and gimbal pitch to about 1/3 of the range and the pitch smoothness to about 2/3.What smoothness settings do you use?
