Today I went to fly a Waypoint Photography mission (M2P) with Litchi where the drone stops at each waypoint, takes the picture and moves to the next waypoint.
before I engaged waypoints, I noticed the gimbal/camera kept pointing up 20 deg above level. I assumed it was my “dumb fingers” resting against the adjustment wheel by accident. when I engaged Waypoints, the camera pointed up at the sky again as it flew to the first waypoint. It flew to the first waypoint looking at the sky and took a picture of the sky, then it functioned correctly at every waypoint after that, but in between the camera would always look up to the sky. I realize now I shouldve tried it with video, (so I’ll try that again later).
Has this happened to you and if so, is there something I can do to correct it?
When I got home, I tried flying with the same setup except using DJI Go4, and it flew fine. I’m thinking I may have accidentally hit a control setting without realizing it. TIA!
