Gimbal rubber band replacement
Praetorian
Replaced a rubber band and took Lots of photos. This isn't a tutorial, just Lots of picture inside a Mavic.
Reactions: mauimark
Thanks for sharing the pictures. As soon as i saw the gimble rubber bands of the Mavic i thought it was very delicate. This bought a confidence that It could be changed locally.
Thanks again. Have a great day!
Your welcome. After you get the gimbal dropped out you can replace the bands. You can see in my last picture where I have the pry tool holding it is where it broke.
Great post - very useful, thank you.
I've just checked the mounts on my brand new Mavic and I see what appear to be 4 mounts but only 3 are connected over the gimbal plate lugs. The one behind the cable running from the gimbal does not appear to be holding anything. Is this normal or should I try to prise the gimbal lug into the holder? If so, any suggestions?
Regards,
Firefly66
Regards,
Firefly66
Defenatly try to get it back on. You may experience a a tilt in your horizon if only 1 is off. They help prevent jello'ing in your video..
Reactions: Enigma
There is absolutely no reason for me to ever be inside of that thing. Wow worse than I thought it would be
I remember watching lot's of videos on YouTube, ( still do ) and one video by Edd Ricker showed him replacing rubber support's with a pair of tweezers.
artfulaltitude
