Gimbal Yaw Arm replacement - calibration steps not working
Tails275
Nottingham, UK
Hoping you guys can help!
I've recently repaired a snapped gimbal yaw arm that occurred due to a crash. The camera itself and cables remained intact and the camera feed worked.
After repairing I noticed the camera was off centre and does not seem to be responding to my attempts at manual control using the remote or in app calibration functions (automatic fails, and I cannot make changes in manual gimbal calibration mode).
I've ran the python calibration steps using:
py comm_og_service_tool.py --port com3 WM231 GimbalCalib JointCoarse
py comm_og_service_tool.py --port com3 WM231 GimbalCalib LinearHall
I noticed that the JointCoarse command worked, making the gimbal move around. However, running the LinearHall command has no effect and the gimbal does not move at all.
What other steps can I try, and is it likely that the cables are damaged?
Have you done the steps below?
Hey thanks for replying.
Yes this is the guide I followed. The python commands I’ve listed are the ones used in this video.
The first command (joint coarse) worked fine, the gimbal moved freely.
The second command (Linear Hall) does not work, the gimbal does not move at all.
Reactions: Cafguy
then you still have an obstruction OR more likely a bad cable
Reactions: skymapper
I repair a lot of DJI drones. The signal cable can look fine but be bad. Generally, if there was any stress to the gimbal, in your case, the broken yaw arm, it is reasonable to suspect a bad signal ptz cable. Im assuming you replaced the yaw axis motor as well because you are talking about the flashing failing. Ill bet the camera is cocked off to the left isn't it? I don't think Ive ever had the Linear Hall step work. If flashing works, which half the time is doesnt, then it always works fine after JointCourse for me. You can accomplish flashing on www.drone-hacks.com website. It is way easier but can take about 10 minutes. If all 3 axis' of the gimbal moved when you tried to flash it, I doubt the signal cable is bad.
Hi, i am currently attempting to calibrate the gimbal on my mini 3 pro after having replalced both arms its centering the camera to the right. Can this procedure be done on the mini 3 pro? I have attempted to do it but the drone isnt showing in device manager under com ports, it shows up as a portable drive. I did read that i would need to have dji assistant 2 installed, and i have tired that but i made no difference. i cant determine which comm port its on.
Have you solved this? its not read by serial comports anymore its Libusb, if you wan to know more, join our telegram channel: Dji Drone Repairs
DJI Assistant 2 is not going to help you with this problem. Anytime any gimbal motor, the camera, or motherboard is replaced, the firmware needs to be flashed. These components are synchronized at the factory to work together. Simply updating/reinstalling the firmware in DJI Assistant 2 won’t work. It isn’t the same as flashing. Flashing resyncronizes the components again. The py-serial method is hard to do. Go to www.drone-hacks.com and download their version V1.47. It is free. Flash your drone through that. Much simpler but takes a few more minutes to actually flash. Some drones take 3 minutes, some take 10 minutes. After you flash it, Calibrate the IMU first then calibrate the gimbal. Then your gimbal should be good to go. Good luck.
resalacademy
