Glasses remote controller will not switch on.
John Gowland
Jomtien, Pattaya, Thailand
The remote controller for my Bt300 glasses will not turn on. It’s the first time it has not done so. Has anyone come across this issue and know of a way to get it going? Mine have had thousands of hours of use with an Air, Mavic Pro, Phantom 4 pro and Mavic 2. They really have lasted a long time. But I would rather not buy a new pair given the hope that there will be software available for the new glasses soon. Is there an easy fix or repair process?
Hey John. Are you referring to the android box? So the CPU won't turn on? I'm not familiar with a "Remote controller" for the BT300s.
If you plug it in, does it respond to the power? Can you turn it on while the power is plugged in?
Are you open to a hard reset?
Given the amount of use, sounds like the power button failed. Seen it before.
John,
Buddy of mine has done a repair. I have pictures if interested, or can put you in contact with him. Bent the switch in. If that is the case, should be an easy fix for you.
John, Have you tried holding the power button in for at least 10 seconds? Do you get a charge indication when connected to the charger? If not, try a different charger and/or cable.
Good to know DVegaman. I'll keep it in mind for the future.
But the
weirdest thing happened this morning. I was about to pack the glasses up to send to Epson for a fix when I did a last check and the dam thing turned on!
wt.. It first flashed green which means booting up then blue, ready to go, then flashing deep orange meaning warning of very low battery.
What seems to have
happened is that it just would not charge with any charger of cable. It then drained almost all power. After a 8 or so hours so was able to use a tiny amount of power to turn on. I managed to see that it was down to 7% of power.
So if it happens to you, having tried all charges and cables leave it for a day and it may rise from the dead.
Reactions: Smalls and DVegaman
But the
What seems to have
Is it charging all the way back up now?
John,
Perhaps when you turned them off they didn't really turn off and went into sleep mode which in turn ran the battery completely dead. On my glasses on several occasions i turned them off and watched them completely shut down only to have them turn themselves back on 30 seconds to a minute later. This condition will drain the battery quickly. Just something to keep in mind. Glad they are working again.
~Bill
nikt_elo
