As DJI actually offers no support for flying the Mavic Mini with goggles and even Litchi developers cannot promise any support because of their dependency from DJI's SDK I have looked around for other options (no, a tablet with HDMI output is no option for me) and found the "XIMMESE Visor X", which takes a standard smartphone with any app running and no need for VR support.
Unfortunately these goggles are only designed for indoor usage and are lacking any protection against light entering from the sides or from top behind the front mirror.
So I have designed sun shields for 3D printing which will effectively minimise that problem. The shields can be attached to the goggles without modification and can be removed for transport.
I have already tested with the DJI GO4 app and it can be operated by either a handheld Bluetooth controller or by Google's "Voice Access" app. The DJI Fly app should behave similar. Ensure that brightness is set to a high level and automatic adaption is turned off.
For connecting the phone on distance to the Mini controller you will need a standard MicroUSB OTG cable which plugs into the left (and only) USB port of the Mini controller. At the other end you can plug in a standard USB cable matching your phone's connector, e.g. its charging cable.
Ideally you buy an OTG cable with 90° connector and also a standard cable with 90° connector to your phone.
I found this OTG cable set and this cable with USB-C connector which works fine with my Mate 20 Pro.
The STL files can be downloaded from Thingiverse.
