Hey doods;
First off, I'm going to qualify my initial assertion by stating that I DID have 2 crashes last year due to prop failures. Both crashes occurred during automated flights. So these crashes were not caused by unpredictable software behavior, run-aways or pilot error. I made a video about those crashes:
Outside those failures, I haven't had a crash in years. I attribute my flight success to a couple things:
1) Practice, practice, practice. Get a small drone with prop guards and fly around the house. If you can fly a small, cheap drone around the house, then your skill level is probably better than 90% of the drone pilots out there. This skill directly translates to more expensive drones, as the controls and behaviors are exactly the same.
2) Don't count on technology to save your ***. While Object Avoidance looks good on paper, in all reality, it's is NOT reliable. A very large percentage of crashes I read about are either due to flat-out failure of the OA, or unreasonable expectations for the OA system. I have TURNED OFF OA on all my vehicles, and don't use it (and therefore, don't COUNT on it) at all.
3) Probably the most important protocol to follow: Find a firmware and software version that work, and STICK WITH THEM. Another large portion of crashes seem to be due to random, erroneous drone behavior. Every time DJI releases a new firmware/software version to be more and more compliant with ever-growing FAA regulation, make no mistake; YOU ARE THE BETA TESTER. I run legacy (read: YEARS OLD) firmware and software on ALL THREE of my birds (Inspire 1, v2, Mavic Pro and P4P), and I could not be happier. My drones are rock-solid reliable, but more importantly, BEHAVE PREDICTABLY.
Here's a list of the FW/Software I use:
Inspire 1:
Go App: v3.1.1
App database: v00.00.01.04
Aircraft: v1.8.1.00
Remote: v1.6
X3 Camera: v1.8.1
X5 Camera: v1.11.1.50
Mavic Pro:
Go App: v3.1.1
Go4 App: 4.0.8
Aircraft: 01.03.0700
Remote Controller: 01.03.0700
Flight Database: 00.00.01.04
Basic App Fly Safe Database: 01.00.01.05
Precise App Fly Safe Database: 01.00.01.05
Phantom 4 Pro:
App: v4.0.8
Aircraft: v1.3.509
Remote: v01.04.01.00
Precise Fly Safe database: v00.00.01.04
Basic Fly Safe database: v00.00.01.04
4) When flying automated flights, an elevated level of diligence is required. Most of my jobs utilize Intelligent Flight Modes or Waypoint automation. Because I don't rely on Object Avoidance, I HAVE to understand my environment, the path the drone is going to take, and more importantly, be on the ready to stop the mission should something go awry. The "ATTI" or "Sport Mode" buttons are your panic buttons. If you're flying an automated flight that looks like it might land you in a tree or smash you into the side of the building, toggle these switches. You can bring the drone back to GPS mode.
5) Test, test, test. Never once have I ever gone into the field with an untested platform. EVERY aspect of that job has been tested with a near-duplicate of that mission under controlled circumstances like a park or open field.
My partner and I just got a job doing extended LIDAR missions with his M600. You can absolutely bet that we are going to test the bejesus out of this BEFORE loading up the vehicle and traveling 5 hours to the job site. I have planned dummy payload flights to simulate the LIDAR unit's payload and current draw. Once those tests have flown successfully, we'll move on to tests with the actual LIDAR unit, which includes data acquisition. You can bet that we will reproduce every nuance of our planned mission, including battery changes mid mission and exit strategies, but in a controlled environment. Which brings me to #6.
6) ALWAYS have an exit strategy. Practice abandoning and recovering from rogue missions. Put yourself in pretend, emergency scenarios under controlled conditions. For example, what if you're flying a remote mapping mission and a low-flying helicopter comes into your mission space? You have to:
A) Pause the mission.
B) Bring the drone down to a safe altitude.
C) Continue the mission.
Without practicing this, you might panic and/or not be able to continue your mission, which means starting over. I HATE starting over.
Anyway, I hope all this helps. I posted this because I see crashes and runaways almost daily in the 3 forums I belong to. I don't fly every day, but I DO fly every week. So my experience is valid.
Good luck!
D
Inspire 1:
Go App: v3.1.1
Aircraft: v1.8.1.00
Remote: v1.6
X3 Camera: v1.8.1
Mavic Pro:
Go App: v3.1.1
Go4 App: 4.0.8
Phantom 4 Pro:
App: v4.0.8
Aircraft: v1.3.509
Good luck!
D
