Google Pixel 2 for controller
Estate
Is anyone using the new Pixel 2 for the controller? Is it compatible?
I'm having trouble finding the right connector which should be microUSB to USB-C
Does anyone know where I can find one?
Any info would be great thanks
why not use the bottom connector on the controller and your regular sync cable to test? i found that connector is better and i can then charge the controller.
Here some 90-degree Type-C cables that'll work for you if you connect your phone to the USB port on the bottom of the remote controller:
tabarton94
