GPS Antenna
raven swe
Sweden X UK
Have a Marco Polo tracker on the way, where is the GPS antenna on a M2Z and an AIR, thinking of placing it up front on both if its not gonna be in the way or interfere with anything
You need to velcro/tie to the rear leg facing outwards when folded.
Mine works perfect for the last two years, never need to remove.
Cheers
I thought its difficult to mount the tracker on the arm because the new tracker has the antenna sticking straight up instead of to the side. So if you mount the new tracker to the side the antenna would be pointed straight out.
adamsc57
