Hi all. My first time posting here! My dad recently crashed his Mavic Pro and damaged the gimbal. He wanted me to have a go at fixing it. I'm not a drone owner at all but I have done electronics repairs.
So I managed to replace the gimbal flex cable and it solved that. Unfortunately, I damaged the GPS module connectors as the wires got detached from the module. I decided the remove the white glue on it and resolder the wires back on and that temporarily fixed it. After taking it for a test flight, it kept switching between GPS and ATTI mode, leading me to assume that my soldering work wasn't done properly.
I resoldered it again but this time, the app says the GPS isn't even connected. I gave up on that part and purchased a new replacement GPS module. However, the same error. No GPS and I can't take off. Firmware has been refreshed and tried different batteries.
I'm worried I may have damaged the connector on the main circuit board. Has anyone encountered this situation and has a solution for it?
Would appreciate any advice there is and thanks in advance.
Problem? GPS disconnected
Was unit in a crash? Yes
What have you tried so far? Read above
What device are you using ( iphone , ipad, Samsung , etc)? iPhone X
What firmware are you running ( aircraft, remote controller)? Latest
What Go app version are you using? Latest
Any modification? (if so what) No
Did you change anything or install any apps? (if so what) No
Do you have a video or pictures of the problem? (if so post link)
