GPS
Aussiemike
Tiwi Beach Kenya
Good Morning.
I need to ask a question.
Hope it is not too silly.
Is it the drone or the controller that picks up the GPS signal?
Can I stand under a veranda with no view of the sky and control a drone.
Cheers MIke
Welcome to the forum.
GPS is in the drone and yes you can fly from under a veranda as long as you as you have LOS. ...Nothing blocking signal between
controller and drone.
Technically it can be both. The drone receives GPS to know its location so it can maintain position in the air, otherwise, if it doesn't have a good signal it may float with the wind as it would not know where it is at, (Generally in ATTI mode) however it does use other sensors to try to see objects on the ground as a second method of holding its location.
If you have a device in your controller with GPS capabilities. The app typically knows your location and allows it places 'you' on the map properly and show the direction you are facing. Additionally you can set your home point to the controllers location. But if you are using a device without GPS, such as a non-cellular version of a tablet, then these options may not be available to you.
So yes, flying under a veranda or in a car, etc will work fine as the most important GPS sensor is on the drone.
Reactions: TTP
it's in both
it's in both
No, not always (especially for iOS tablets)...but for the OP's question not relevant to main question of veranda and pilot location.
To the OP this is very disturbing unless your flying EXTREMELY low.
BlackRoc
