Greetings from Bedford in the UK
Hey Guys, hows things, new to the drone scene, just got back from a week in Devon where I have been practicing with my new drone, DJI Mini 4 pro, Managed to get a couple of videos up on my Youtube account and quite pleased with the results. :)
Wotcher from the West Midlands..... hope you didn't drink the tap water!
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
hesitantextraneous
