Greetings from Colorado
970Drone
Colorado
Hi all! Recently discovered the mavic pilots platform and have loved it so far. I'm Nathan, and have been dabbling in amateur drone work across Colorado. I've been considering investing in some more professional equipment so that I can utilize thermal, lidar, and high quality imaging for infrastructure inspection, mapping, and photography. Always looking for work and to network with people in the industry. Excited to join the community!
Welcome to the forum! :)
Welcome Nathan! Like you I'm a new member (today) and drone noob!
Been several times and even lived in the US (Cali), but my lifelong dream US destinations are Montana and Colorado! Lucky you to live in such beautiful surroundings. Pretty beautiful here too, but missing your dramatic mountains and just "everything bigger" :)
Anyway, from noob to noob - big welcome!
Best!
/M
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). If Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. If it weighs more, you need to register it…
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Colorado, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Thanks for all the good info. I really appreciate it!
Reactions: LoudThunder
What part of Colorado do you live in?
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you have. Search the forum using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response! Fly safe and stay safe!
tagir
