Hello, new to the drone community, I just bought a used DJI Mini SE and I am looking froward to learn about the hobby.
Maybe we could get together at some point and exchange tips. I’m planning to go to Richmond park.Another Brit, DJI Mini 3 Pro owner. Hoping to get out tomorrow to use it to fire up the propellers for the first time. Weather in the UK has been crap for a month.Rain and wind or just wind or just rain.
Welcome aboard anyway!
Yeah that would be good, I’ll follow you.Maybe we could get together at some point and exchange tips. I’m planning to go to Richmond park.
Thank you for writing this welcome message, Loud Thunder and thank you for all those advices.Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Map…" Check it out and you might find some new flying friends.
Member Map
mavicpilots.com
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Overview : Flying drones and model aircraft | UK Civil Aviation Authority
Find out what you need to know and do when you fly drones or model aircraft in the UKregister-drones.caa.co.uk
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini SE, including the User Manual.
Fly On and Fly Safe…
