Greetings from Malawi, Southern Africa
I am currently flying a air 2s
Since you live in Malawi, there are specific laws and rules for you to follow, please check to ensure these are current.
Even though you have flown Drones before, here is some Good Old Fashion Advice that might keep you from evr hitting those power wires again, or anything else…
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Fly On and Fly Safe…
Desert Sand, welcome to the forum! You live in a fascinating country. I saw the must-see movie, The Boy Who Harnessed the Wind. It made me want to visit Malawi! Below is a link to the manual for the Air 2 S, in case you don't have it. Glad to have you aboard!
Rich R, Hurst Texas
Its a beautiful country, im from the Democratic Republic of Congo but fell in love with the country after visiting with my wife who is from here, been living here for 10 years now, beautiful landscapes
Never did this before tp be honest in 4 years of flying drones lol, but its never too late to learn and to start... i appreciate the time you took to answer me. Thanks
Welcome to the forum! :)
marcusjohn3684
