Greetings to friends who love drones here, I come from the city of Chicago
Hello from the Crossroads of America dronelost.
Depending on what you are flying, it might have to be registered with the FAA.
You need to take the TRUST test and keep a copy with you when you fly.
It's a free no fail test that's easy to take that covers the basics of flying a drone.
Good luck and welcome to the Forum. :cool:
I hope I can learn a lot about drones in this forum.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
Another member, @MA2 317, has already advised you on your legal requirements, so I will not repeat them here, but I will remind you that they need to be done…
Since you live in Illinois, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Welcome to the forum!
Whats your experience flying some thing in the air that doesn't have a string? :)
I good day can go bad really quick. :rolleyes:👌
Rod ..
marcusjohn3684
