Had the dreaded gimbal overload message yesterday!
Hi guys,
As per the above, booted the Mavic up yesterday wanting to get some footage. Gimbal was doing some funny things and was kinda in a fixed position but pointing up and could not be adjusted on the controller. Did a couple of reboots and still no good. I ended up giving the gimbal a gently poke and it freed allowing me to get the footage I wanted. Just booted up again and it seems fine, having had a visual inspection and doing a calibration I noticed that the screw under the camera lens looks loose? I’m guessing this is not normal?
Please see image attached.
Cheers
Thanks man, at least it rules that out. It may have just been a temporary glitch. I’ve read it’s a common issue. I’ve only flown about 12/12 times and without collisions so not down to damage.
Yes, that's normal.
Umrahtaxiservice
