Hard case for Air2S and RC Pro
otacon
Arizona
Is there any hard case for the Air2S FMB and RC Pro controller? The hard case I had with the FMB didn’t work. I bought another one for the Smart Controller but of course the Smart Controller and RC Pro aren’t the same size. I can just get a hard case with pick and pluck foam but I’d rather find one with cut foam.
I spoke with B&H about this because I had ordered the combo with smart controller, and then they switched my package to the RC pro and the dimensions are diffrent. So I had to cancel nanuk case. He said it will probably be a little bit before they tool up another case to fit the new Pro
Cheers!
Cheers!
Thanks. I think I’m going to buy a soft case for right know until things catch up.
Reactions: PalmettoAerial
Look for a camera bag instead of a drone bag.
I bought the “Lykus M1 Water Resistant Travel Backpack for DJI Mavic 3, Mavic 2, DJI Air 2S, DJI Mini 2, 4-in-1 Backpack/Case/Shoulder Bag/Cross Body Bag” It has movable dividers and can fit the 3 with RC Pro controller so I’m sure it will fit the Air2S with RC Pro as well.
Take a look at PGYTECH backpack OneMo Camera Bags & Accessories The most incredible combo version you can imagine , the color you see on the picture and a black version , you can get it at Amazon as well...
Reactions: PAW
I just sent an email to GPC inquiring about if they're adding a different insert for the FMC plus RC Pro. I have the one for the standard Air 2S FMC with regular controller that has a removable insert for the Smart Controller. I'll follow up when they respond as they make incredible products.
I got the hard case from DJI for the Air 2 and my Air 2s fits fine. The case can take the normal RC or the Pro RC.
It has a foam insert for the normal RC. The down side it that it's $169
I have the VCUTECH case I got off of Amazon and I don't see it ever being able to take the Pro controller even with a different foam insert. It doesn't have the updated cut out for the square ND filters either. Luckily I'm in Amazon's extended return period on both cases I bought that won't work. I too am curious about the GPC.
I have the same VCUTECH case. If the ND filters are left in their case, there is a slit to the right of the drone pocket where it is supposed to go. The thin small insert in the RC pocket is to separate the remote from the charging cords.
My bad! You're right about the ND filter slot... I just wish it could hold the RC Pro. I guess I could cut the foam but it would be a hack job at best.
They had enough room in the VCUTECH to allow for the Pro RC. Not sure why they didn't make that an option.
I would be curious as to what case you end up with.
I actually just ordered the same one. It looks pretty slick and fairly compact.
This is the Air2S and RC Pro controller in it. I put two microfiber cloths under the drone so the top strap holds it tight. Should easily be able to fit everything else from the FMB in it and then some. Could probably put the controller up too if you wanted. Might actually do that lol
I cut the foam in my VCUTECH case and can fit the Air 2S and RC Pro plus the new Lifthor RC Pro mount, but not attached to the remote.
I am searching for a hard case in which I can leave the Lifthor attached and also fit a Feelworld 279S in with a quick adapter on it so all I need to do is attach the monitor and fly.
I may have to go soft case or buy one of those hard cases that require you to custom cut the foam.
What does the new Lithor look like? I bought one for my SC...but now I need one for the RC Pro.
Here is a link to what I bought.
RC Pro
I will upload a couple of pictures on the controller soon.
Correct, but the bracket can be separated easily.
Bandar200718
