My searching has failed to find any testings comparing the performance such as top forward and acceleration speeds when using 4P batteries in the 5P?
One notable crash reported due to insufficient voltage leading to power loss and shutdown midflight. DJI now strongly recommends against using anything other than M5P batteries in the M5P.My searching has failed to find any testings comparing the performance such as top forward and acceleration speeds when using 4P batteries in the 5P?
Check with DJI. After the crash, which they covered, they now no longer claim compatibility and recommend against using any other batteries. The voltages are different. Use at your own risk. Success is not crashing. Failure is usually fatal. Like playing Russian Roulette?Proof of crash? Also proof of successes.
I have a dust-collector I call my mini 4 pro. Haven't used it in abt a month's time since I picked up my mini 5 pro. Surprised that the m4p battery fit in the newer m5p, so started using it. I am a longtime still photographer with cameras, now using the m5p for the same purpose but at higher perspectives for a new angle.One notable crash reported due to insufficient voltage leading to power loss and shutdown midflight. DJI now strongly recommends against using anything other than M5P batteries in the M5P.
