Hi !
We talked about it a lot of times, here are facts
I am using this cheap dongle:
MiraCast 5G:
Mirascreen 5G TV Dongle
(can be had from $12 up to $50, your decision ;-) )
Setup:
you can set the dongle to Airplay (usually iOS, see below) or MiraCast (Windows / Android)
I encountered a problem with my S7 Edge, latest FW cobinations would not work good with MiraCast, ALL my others do work so i guess its Samsung to blame...
So i installed the "Mirroring 360 Sender" App which allows Android to mirror to Airplay...
Apart from that MiraCast worked fine some time before...
So i setup the dongle to start in Airplay mode, 5GHz frequency which is great as it does not interfere with Ocusync !
fired up the Mavic, connected S7 to Controller, used an iPad as reference time source (stopwatch app) and focussed the Mavic on the iPad.
Connected the MiraScreen 5G to a small HDMI Monitor and mirrored S7 Screen via that 360 App...
I then started the stopwatch and took a still image with my Yi Actioncam to see the lag.
Endresult:
-190ms from "real time" to S7 Edge
-Another 120ms from S7 to the Monitor via 5GHz WiFi Dongle totalling in 310ms.
As the Mavic is no racer anyways i think thats okay for gentle flying and spotting !
I'll used a powerbank with my Eachine Goggles Two to supply the MiraScreen 5G but will solder a 2S LiPo to 5V stepdown ($0.50) in the weekend to use the Goggles battery and to then have an "Aitplay & MiraCast" Goggle
GREAT,
Ender
MiraCast 5G:
Setup:
Endresult:
GREAT,
Ender
