Head over shot
fredgsy
Basic question - how do you either ascend or descend whilst rotating - yaw- the Mavic to get those shots ? Same stick is used - so any help would be appreciated
Yes, practice, and be careful not to shut down your mavic with sticks in bottom corners!
Reactions: fredgsy
Depends on speed of ascending/descending and yaw rotation you want to achieve
By Yaw I assume you just wish to rotate the Mavic around its camera axis while ascending or descending to get a spinning effect which you have figured out . You can also Fly in POI mode and select the Point Of Interest you wish the camera to remain focused on while it circles around it . After setting an initial radius , height and speed to start you can also manually adjust the radius , height and speed while it is circling the POI to get a spinning , funnel effect .
Reactions: fredgsy
Jrwooley4
