Heat problems
mickeren
I'm on Holliday in Sardinia in Italy I letter my magic in the car for some hours and then agent forms flight? I could connect for 5 seconds then the bird agent disconnected?tried restarting all but same problem. When we can to the hotel I tried again and not worked fine. Only difference Shaw the temperature. It's 30 deg outside and in the car it was surly much more
Have anyone had sand experience?
Having trouble with your English above, but cutting short the worst abuse is to the batteries, so let them cool off and then see what the battery status page shows in DJI GO for each battery. Check the controller as well as its battery may have been abused too. If your batts show uneven cell voltage (more than a few mW) try to re-charge them _after_ they have cooled to room temperature. The batteries will manage the voltage levels quite well.
If you had to go through that, then after recharging, check them in DJI GO app again for even cell voltages before flying. They should be within a few mV of each other.
While it may be 30°C outside inside the car it can get wicked hot as you know. Batteries do not do well with heat.
Electronics, generally, do not like heat.
Interceptor650
