Proud new owner of a
Mini 2,
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
mavicpilots.com
Since you live in Greece, there are specific laws and rules for you to follow, please check to ensure these are current.
According to HCAA, drones are allowed in Greece, subject to HCAA and EASA regulations. Read on for details.
drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mini 2, including the User Manual.
At DJI Download Center, Learn aboutDJI
Mini 2
www.dji.com
Happy, Safe and Legal Droning…
