Hello all
"learn all I can from y'all." Love it !!
I good day can go bad, really fast.
also
Stay away from Mavic Magnets 🌲 🌳
Welcome to the Forum.
Rod ..
Bought a DJI Mini 2 and hope to learn all I can from y'all.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
A few useful things to get you started:
  • The current Mini 2 manual can be downloaded here (it doesn't come in the box). You can find other commonly used Mini 2 downloads here.
  • This video covers all the basics of the (drone).
  • Your drone batteries will last longer if you use and maintain them like this.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
Welcome to the forum. We look forward to your participation and your view of the world.
Reactions: old man mavic
Robby1983
