Hello from Brenham TX (outside Houston)
astrohip
Brenham, TX, USA
Hello from Brenham TX. A small city of 15,000 about an hour NW of Houston. Just got an Air 2S last week, and can't stop having fun with it! I'm lucky I'm out in the country, so I can go flying (droning?) for miles around.
Looking forward to tips & tricks, and just learning more about my drone (and all drones).
ME: Retired, lived & worked in Houston all my life, moved here about 15 yrs ago. Always wanted a drone, and finally pulled the trigger.
Hello from the Crossroads of America astrohip.
Welcome to the Forum. :cool:
Welcome to the forum! :)
Here are some things to help you get started with your drone:
  • Download the DJI manual for your drone here (it doesn't come in the box). The manual is packed with lots of useful tips and will give you a better understanding of your drone's features.
  • Check out this getting started guide for some tips not found in the DJI manual.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
You live in a place that has such incredible geography within a day's drive. My home town isn't much but if I take a day and am willing to put some miles on I can find places to fly and I'll bet you will too. Have fun.
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs more than 250-grams (0.55 pounds) and if you are flying under The Exception for Recreational Flyers, you are still required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my Mini 2 under Part 107.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Happy Droning…
Hello from Minnesota and welcome to the Forum....Congratulations on your Air 2s great drone...There's a lot of good quality teaching/feedback going on in here. Just ask, and the experts are great on providing good sound advice for you to apply and use... Remember to always Fly safely and fly smartly representing all of us drone hobbyist well.
Thanks for checking in. I live in Sugar Land but really love flying in Washington County. Aside from the Blue Bonnets in the spring, there are some beautiful views around Burton and Round Top, among other places.
<snip>
Happy Droning…
Thanks, all good info! Didn't know about registering. Will do...
We live about 1 1/2 hours south of you. Any way I can get you to tell me when the bluebonnets start popping up? It would be nice to have a local person with up to date info on them
JefScot
