Hello from California
Just got a Mini 2 - plan to use as a scouting tool for my main hobby (Landscape photography). Excited to learn here!
Greetings from Birmingham Alabama, welcome to the forum!
Hello from the Crossroads of America trale.
If you haven't done it yet, you should take the TRUST test and keep a copy with you when you fly.
Although the mini 2 may not have to be registered with the FAA, if you add accessories to it and push it past 249 grams, then it should be registered.
It's only five bucks and the numbers look cool.
Good luck and welcome to the Forum. :cool:
Welcome to the forum! :)
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
As a New Drone Pilot, MA2 317, one of our members has already given you the TRUST Heads-Up. But you may need to get your Part 107 License once you start to use the Mini 2 in conjunction with your hobby if there is any recompense for your photos. Right now, before you use it for "Scouting" it's all for fun. If you sell any of the photos, it's a business and it's for "money" and the FAA is serious about that… If you intend to register your drone and intend to get your Part 107, hold off on registering your drone. If you register it for recreational flying, you would be required to re-register it again under Part 107.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Since you are New, here is some Good Old Fashion Advice…
Do not take you drone to the job site until you KNOW how to fly it. You do not want to fly it into a house, a tree, other obstacle with a new client…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy, Safe and Legal Droning…
Welcome to the forum from Australia, you might find that your scouting tool becomes your photography tool being able to get the perfect angles where the light is falling on subjects...
nikt_elo
