Hello from Canada
I'm a long time amateur photographer and I've had a mini 2 for a couple years.
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Eventhough you have flown Drones before, here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
Greetings from Birmingham Alabama
I'm a long time amateur photographer and I've had a mini 2 for a couple years. I'm glad I found this group to go the next step with my skills.
Welcome, from Hamilton, Ontario!
Badeff
