Hello from England
The-Hive
England
Hi everyone.
My name is Rod and I live in England, just south of Salisbury on the edge of the New Forest. I worked in photography for 30 years with Kodak and I am related to the Eastman family. It is great to use the Mini 4 Pro to photograph the world from a different viewpoint
Welcome to the forum! :)
Hi everyone.
Welcome Rod to the community.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Rod?
Nobody has a name like that.
Look up Yendor on the internet, I have people will call me that now. :)
Most important to me, what is your experience operating a bird in the air?
A good day can go bad really fast.
BTW, Welcome to the forum!
Rod ..
marcusjohn3684
