Hello From Georgia USA
New DJI Mini 2 pilot. I have flown twice now. I'll be having some questions for people with more experience.
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum! :)
Hello from the Crossroads of America Uzi.
If you haven't done it yet, you should take the TRUST test and keep a copy with you when you fly.
Although the mini 2 doesn't need to be registered with the FAA, but if you add accessories to it that may push it past the 249 g limit, then it will need to be registered.
It's only five bucks and the numbers look cool.
Good luck and welcome to the Forum. :cool:
Welcome to Mavic PIlots! :) Enjoy the forum!Thumbswayup
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Another member, MA2 317, has already given you the heads up on the legal requirements for your Mini 2, I just say that I registered my Mini 2. It gives you an FAA Registration number and some additional measure of authentication along with your TRUST Certificate…
Since you live in Georgia, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Since you are new to Drones, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy, Safe and Legal Droning…
sistersister300
