Hello from Germany
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum. It's fun communicating with other pilots here. Mini 3 pro is a great drone to play with. If you happen to look for a handy case to carry and protect it, check out our MM330 hard case. Enjoy!
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
I live in Germany but i am originally from Romania. I am a new DJI Mini 3 Pro owner.
Since you live in Germany, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy Droning…
Welcome to Mavic Pilots!:) Enjoy the forum!Thumbswayup
Welcome to the forum! :)
Welcome from NC, Can you fly drones in EU ? (I'm from Sweden)
Hello everybody. I live in Germany but i am originally from Romania. I am a new DJI Mini 3 Pro owner. I researched for a few days and decided to buy this drone. I'm a beginner. I look forward to learning more from you.
Thanks.
Greetings from Colorado, USA🇺🇸, welcome to the forum🎄
Roel Hopstaken
