Hello from Illinois!
Greetings from Birmingham Alabama USA, welcome to the forum!
Hello from the Crossroads of America sray86
If you haven't done it yet, swing by the FAA and register the aircraft.
FAADroneZone
Also, take the TRUST test and keep a copy with you when you fly.
Welcome to the Forum. :cool:
Good info! I have already done all this but it's definitely a good policy to let the new guys know how to be legit!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum! :)
Just got my Mavic Air 2 on Thursday
https://mavicpilots.com/dbtech-membermap/
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) Your Drone weighs more than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are still required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Illinois, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Air 2, including the User Manual.
Happy Droning…
hafizur
