Hello from Kalamazoo
Good Dog Jack
Michigan
Hi from South West Michigan!
Really looking forward to flying a new Air 3s I just received it yesterday UPS.
I flew a bit years ago with a Parrot II and a home built 3DRobotics, but it’s way different now days. Way different in a lot of awesome ways, technology is just amazing, really!
Considering getting a wet suit on it too. I’d like to film some weather/cloud fronts as they roll in across the fields as my skills permit.
Some vendor storm videos looked crazy capable so I’m interested.
Thanks,
Craig
Since you are just getting back into the sport, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Michigan, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic Air 3S, including the User Manual.
Fly On and Fly Safe…
Thanks,
Craig
Welcome to the forum Craig. Just east of you, between Detroit and Ann Arbor.
Remember trees are not your friend.
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members who are willing to help you with any questions you might have. Search the forum using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response!!
Fly safe and stay safe!
Thank you for such a comprehensive greeting!
I’ve had the Trust cert for a couple months as I’ve been flying to practice up with a more economical machine. It’s not the 3s but I’ve had good fun with it!
Just registered as a rec drone at the drone zone after discovering my serial number is my Remote I.D., love me some Google.
Thanks Again,
Craig
Welcome to the forum @Good Dog Jack! :)
After flying many DJI consumer drones since 2016 (I own most all of them), here's what I recommend you do (at the minimum) to get started with your DJI drone:
  • Skip buying a non-DJI practice drone and start with any of the DJI consumer drones (ideally the model you'll be flying most). While it's true DJI makes one of the most expensive consumer drones, you likely won't learn much about your DJI drones by flying drones made by other manufacturers. And then you'll be back to square one again when you finally decide to ditch the practice drone and start flying a DJI drone.
  • Before attempting to fly, watch some videos on YouTube.com to learn more about your drone. Search for something like "Mini 2 Beginner's Guide" (replace "Mini 2" with your drone model).
  • Read the DJI manual (available in the "Products" section of the DJI Download Center) from beginning to end (maybe a few times). You're certainly not going to remember everything, but it'll give you a good understanding of the available features and capabilities of your drone. And then you can go back to the manual or YouTube videos when you need to take a deeper dive into a specific topic.
  • Before flying in the US, you must register your drone with the FAA (if it weighs 250 grams or more) and take the free online TRUST test (I like this one).
  • When flying in the US, your drone must broadcast RID if it weighs 250 grams or more (or is registered with the FAA). Many DJI drones (especially the newer models) have that feature built into them. If you're ever flying a drone that does not broadcast RID (meaning it's not on this list), then you'll need to attach an external RID module like the Holy Stone or Ruko RID module.
  • Don't power on your drone or take off when within about 20 feet of any magnetic metal objects (like your car or rebar in concrete sidewalks). See more on compass interference in this compass calibration guide.
  • Before taking off, always review the drone settings in DJI Fly (or the app you're using) to ensure everything is set as expected. If you do plan on flying near any obstacles, ensure the RTH altitude is set properly in case your drone needs to automatically return back to the home point mid-flight.
  • Never take off before DJI Fly (or the app you're using to fly) audibly mentions or shows the home point has been set. The drone will attempt to fly back to the home point location automatically if it loses connection with the remote controller, so it's crucial to ensure that location has been set prior to takeoff.
  • DJI drones have a lot of awesome automated flight features. Use them with caution and never assume they are always going to function as expected (always be ready to take control if needed).
  • Sensors are great and they can help prevent your drone from crashing into obstacles. They are not foolproof though. Never rely on them 100% or assume they are going to work perfectly in all flight conditions -- or react the same way when flying in similar conditions from past flights.
  • Find a flat, wide open place to practice (free of people, trees, and all other obstacles). It's pretty hard to crash a DJI drone into the ground, so you'll likely have the best success if that's your only obstacle. Continue flying in this location (or similar locations) until you're able to control your drone without thinking about it (like riding a bike).
  • Make sure you can easily see your drone at all times (required by law in most countries). After removing all nearby obstacles, nearly everyone who crashes/loses a drone is either not watching it with their eyes or cannot clearly see where it's located.
  • The screen is chock-full of great information. Use it as a reference (sparingly) as you do when looking at your dashboard while driving a car. It's also a great tool for framing the perfect photo or getting your drone in just the right spot before hitting record. If you're mostly staring at the screen while flying, you'll probably have no idea where your drone is located.
  • Don't fly in sport mode until you're comfortable controlling your drone. You don't want to get into a situation where you need to maneuver quickly and aren't quite sure which stick to move (another reason not to practice near obstacles).
  • DJI batteries require special care that is unlike other batteries you commonly use. To prevent any damage to your DJI batteries, follow the tips in this DJI battery maintenance & storage guide.
  • DJI drones record a lot of useful information in the TXT flights. The logs are helpful for things like troubleshooting issues you experienced during a flight, locating a lost drone, and many other things. The TXT files can be found on your phone/tablet or remote controller (if it has a screen). See these instructions for more details. And then you'll need a tool like my free online DJI log viewer or Flight Reader (keeps your flight logs offline) to decrypt and access/view the data within.
Thanks for all the good information, battery storage is enlightening,
I’ve read good discussions on data interpretations of a specific flight log vs the pilot’s recollection and found them interesting. I can see where your log viewers would be helpful, another goal.
Thank you for taking the time to provide this useful material. A lot of good references in these posts!
Craig
The Air 3s is now registered with the FAA and I have my FAA number.
Already had a Trust cert., and have a wet suit on order. Come on Spring!
After installing the wet suit, any recommendations on where to mark the FAA and phone number?
Thanks,
Craig
I had room on the front of my MA2 between the sensors for the numbers after I applied the wetsuit.
The arms work well too.
Another place to store information is on the SD CARD as a simple word file.
If the drone is lost and someone finds it later, the information on the outside might be compromised due to the elements.
The information on the card should remain intact.
RobertCNewman
