hello from Maryland, USA
Hello from the Crossroads of America Frankoqm.
I still have my SPARK but it flies drunk after a collision with a tree. I replaced the camera and I think the IMU is compromised. :(
I really liked the flying brick but have moved on to a Mavic Air 2.
Have fun with your current aircrafts and welcome to the Forum. :cool:
I currently have a Spark which i now want to replace for a mini pro 4.
As an "old timey Sparker…", there are a couple of Legal Things you may need to do in case you have not kept current with the latest news and trends…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Maryland, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
When you buy that new bird… Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
Spark eh! Was good choice to get started and will stand you in good stead for the M4Pro. Loads to work on though and Loud Thunder’s piece always well worth a read. Fly safe and enjoy.
Welcome to the MavicPilots forum. I’m also a Marylander, living in Laurel. Enjoy safe and happy flying!
Thank you and looking forward to a mini 4 pro.
Reactions: LoudThunder
Thank you much for all this contend and recommendations. Much appreciated.
kaidoestech
