Hello from Massachusetts. Just received a
Mini 2!
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
mavicpilots.com
Congrats on getting the TRUST Certificate. Your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my
Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the FAADroneZone You will find all the latest FAA Info here and if you decide to register your Drone, you can do it here. You can create an account and you do not have to register the Drone (Optional for Drones under 250-Grams…)
faadronezone.faa.gov
Since you live in Massachusetts , there are specific laws and rules for you to follow, please check to ensure these are current.
Drones are allowed in Massachusetts for recreational and commercial use, subject to FAA and local regulations. Read on for details.
drone-laws.com
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mini 2, including the User Manual.
Learn and download
DJI Mini 2 related apps, software, and manuals at the DJI Download Center
www.dji.com
Happy, Safe and Legal Droning…
