Hello from memphis
Hello from the Crossroads of America memphiscbrider.
Nice to meet you Patrick. 🤝
If you haven't done it yet, you need to take the TRUST test and keep a copy with you when you fly.
It's a free no fail test that's easy to take that covers the basics of flying a drone.
This app will help you navigate the airspace and you may get permission to fly if near an airport.
Good luck, have fun, and welcome to the Forum. :cool:
If you don't have much experience with flying some thing above your head with out a string.
A good day can go bad really fast, been there. :rolleyes:
Always stay away form Mavic Magnets (🌲🌳)
Almost forgot,
Welcome to the Forum!
Rod ..
Great information. Thank you. Course was super easy to. So long as you read it. Lol
Almost forgot,
Rod ..
I've noticed that already. Lol. Those trees do tend to attract flying things to them
just picked up my first drone on black Friday. It's a mini pro 3
As @MA2 317 advised, there may be a couple of Legal Things you may need to do…
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Tennesee, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Thanks for all the great information. I will definitely be putting my number on it. Any recommendations on what to use? Such as a permanent marker, label maker?
"Thanks for all the great information. I will definitely be putting my number on it. Any recommendations on what to use? Such as a permanent marker, label maker?"
That post can get really crazy, I have my thoughts. I will just watch for now. 👌
Rod ..
Welcome to the forum! :)
I registered my drone with the FAA in the beginning, so I had a FAA Registration Number and the Pilots Institute makes and sends FREE stickers… I have since acquired my Part 107 License and gotten a new Registration Number and both labels never faded nor came loose.
I do not know if they also offer free labels with only your phone number. Try emailing them…
In the meantime, I would write the phone number with ineligible ink (Sharpie Marker) and then tape it in place with clear packing tape or that clear sticky plastic for covering photos, id cards, etc… and put it someplace obvious. If you put in under the battery, the finder may not see it…
Also, your idea of a Label Maker is Good, "If Found, Please Call xxx-xxx-xxxx"
If you make a homemade label, and it fades, just make a new one…
Reactions: wjkrysak and RodPad
marcusjohn3684
