Hello from Minnesota!
Aquaelie
MN, USA
Hello everyone! It’s great to be here with like minded individuals. A little about myself. I am an IT pro who likes new tech toys, photography and aircraft. So, naturally, flying drones is the intersection of all my interests and hobbies. My first drone was a Mini 2 last July and since sold it and moved into a Mini 3 pro. I mostly fly over Lakes and rivers in MN around golden hour and just before sunset to capture all the highlights in the gorgeous MN skies. I have about 13 hours and 80 flights logged and am hoping for more this summer and fall. I already registered my drone in the Drone Zone page. Hoping to meet some like minded folks here who I can learn from.
Quick question. Would y’all buy an Air 2 for $300 USD with the fly more combo even if you had a Mini 3 pro? I was wondering if it is going up for sale due to the RID requirement coming into effect in Sept and was reading that the Air 2 may not be getting the update at all or could be delayed. Can some folks shine some light on the Air 2 cost being worth it or am I just throwing money away? Note: I have the DJI RC and a RCN1 already.
Thank you for your time and feedback.
I guess that’s up to you. I’m not sure that I would.
Hi Aqua, welcome to the fourm. Not sure I would go with the Air 2, from where would you be getting the Air 2 FMC for $300?
BTW, I have/had both and I kept the Mini 3 Pro and I gave away the Air 2 to my brother....but that's just me.
I discovered the deal on my local Craigslist. Seems like a decent deal but then remembered I sold my Mini 2 cuz I didn’t need or want an extra drone laying around. 🤪
Welcome to the forum! What are your planned uses? Are you a recreational flier or are you thinking of getting into more commercial work at some point? If you could get a hold of an Air S you wouldn't need to worry about RID. If you're thinking of going commercial work at some point, you'll need your Part 107 from the FAA. No rush as long as you take your time and don't do any paid work before you're Part 107 Certified.
Secondly is budget. If money isn't an object, an Air 2is really, basically, the same air craft and camera as the Mini 3 Pro, PLUS, with the Mini 3 Pro you can do vertical video & pics. If your budget allows - wait for the Air 3 S. It will be dropping any day and will come with RID compliant build in.
Hello again from the Crossroads of America Aquaelie.
I enjoy my MA2 and waiting for the RID update...if one is coming for it?
I know it's an older aircraft in the DJI fleet, but it works for me.
A recent post in an article from Drone Dj indicates that DJI may upgrade the MA2, but it'll be a couple of weeks after the September deadline. 🤔
I may purchase an Air2s as a replacement aircraft because it's RID compliant and all of the MA2 stuff will work the Air 2s.
Good luck and welcome to the Forum. :cool:
I feel like you helped me decide against getting it. I was wanting it for the ADS-B functionality to give me more peace of mind since I have had some very close calls with older airplanes flying below 500 feet in uncontrolled air space. I may just use that money for some strobes and ND filters then. Thanks for the input!
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs less than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live Minnesota, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Even with 89 lights under your belt, here is some Good Old Fashion Advice…
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
The resources you listed for the laws were very helpful! Some of the places I was hoping to fly have ordinances against flying drones! You saved me a lot of research time and potentially kept me out of trouble! Thank you very much.
Welcome to the forum! :)
Welcome to the forum from NW Montana. I have MA2 & love it. Very dependable machine using several different apps including Litchi. Never a glitch for me. The camera does a decent job but there are better ones available on newer models. However, I would never buy one off Craigslist.
You are welcome. That is why we are here, to help each other, to learn from each other, and to pass on the wisdom we have learned. If you have other questions, it might be advisable to open a new topic in General Discussions or maybe your drone's sub-forum, as the most knowledgeable folk may not be monitoring the Pilot Check In forum…
Fly Safe..
Reactions: Hauptmann
Welcome to our forum, Aquaelie, from Hauptmann, in Hurst, Texas!
You'll love the flexibility of vantage points an aerial camera platform affords--you'll get shots and videos you could only dream of before! I fly a Mavic 2 Pro now, but will soon add a Mini 3 Pro to my “fleet”.
The Mini 3 Pro is an excellent choice. It has a great camera, and with its sub 250 gram weight, it is not subject to many regulations aimed at larger, heavier drones—especially in Canada and EU/UK. As to a second drone, I agree with hagman23--I'd wait for the Air 3S. It should be out any day now. BTW, Loudthunder offered great advice--take the time to follow his recommendations. It could save you a lot of grief.
We have over 150,000 members—many from Minnesota--who enjoy helping each other get the most out of our hobby. Most of the questions you'll have will’ve already been addressed, and are easy to search. If you have NEW questions, just ask!
I've attached a couple of links below, which will make learning piloting and photo/video skills easy. The author specifically refers to the Mini 3 Pro, but his “moves” apply to any drone (DJI, anyway).
Glad to have you with us!
Rich R (aka Hauptmann)
https://www.youtube.com/watch?v=c1j9VqmDYEI&t=497s
https://www.youtube.com/watch?v=vK6s2hJLRRE
Hello from Minnesota and welcome to the Forum....There's a lot of good quality teaching/feedback going on in here. Just ask, and the experts are great on providing good sound advice for you to apply and use... Remember to always Fly safely and fly smartly representing all of us drone hobbyist well.
Azra
