Purchased a
Mini 4 Pro earlier this week. Had a toy drone several years ago that I lost the first day!
mavicpilots.com
Since you live in Pennsylvania, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
44809 is an exemption from Part 107 drone laws. This means that drone pilots fly under Part 107 drone rules by default unless they meet all 9 of the requirements to fly under 44809, the exception for limited recreational operations of unmanned aircraft. You can read more about these requirements...
pilotinstitute.com
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the
Mini 4 Pro, including the User Manual.
Learn and download DJI
Mini 4 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
