Hello from Norfolk UK
Welcome to the forum! :)
Hello from the Crossroads of America DamoVit.
Toy drones are easy to crash.
DJI drones are easy to fly.
Good luck with your research on which one(s) to purchase. You can own more than one.;)
Welcome to the Forum. :cool:
if the cost is not a factor in your purchasing decision ,then go for the Mini 3pro fly more with the RC controller with the built in screen ,it is an amazing bit of kit and you will have a lot of features
nothing wrong with other drones in the Mini line up,but the Mini 2 is getting a bit long in the tooth now
new to drones but will definitely be getting a DJI, can't decide between a Mini 2 or Mini 3 as yet LOL.
Since you live in the UK, and you wrote tht you will getting your "flyer and operator ID", just be sure it's all you need… please check to ensure these are current.
Since you are undecided about which drone to get, watch lots of YouTube Videos for all the drones under consideration.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 2, the Mini 3, and the Mini 3 Pro, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
My budget is quite low so sadly the Mini3 pro is out of reach. I’ll continue enjoying my research.
I fly the Mini 2 and I love it. I would not recommend going lower than the Mini 2 series. Depending on how tight the money is, consider a DJI Refurbished Drone. They offer a significate savings and they come with the same warranty as the new ones and they are eligible for the same Care Refresh Insurance (Highly Recommended, or a similar policy…).
This is the DJI's United Kingdom Web Site for their Refurbished Drones…
Good Luck, Fly Safe…
Roel Hopstaken
