Hello from North Central FLA!
Hello from the Crossroads of America Mcfly82.
If you haven't done it yet, you need to take the TRUST test and keep a copy with you when fly.
It's a no fail test that's easy to take that covers the basics of flying a drone.
If you add weight to the mini (strobes, prop guards, etc.) you'll need to register it with the FAA if over 250 grams or you plan on using it as a Part 107 certificate holder for business opportunities.
Good luck.
Have fun.
Welcome to the Forum. :cool:
Good luck.
Have fun.
Thanks for all the great tips!
Welcome to the forum! :)
A few useful things to get you started:
  • The Mini 2 SE manual can be downloaded here (it doesn't come in the box).
  • You can find other commonly used downloads on the Mini 2 SE downloads page.
  • This video covers all the basics of the Mini 2.
  • Your drone batteries will last longer if you use and maintain them like this.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
Welcome from Vero Beach, Florida! We're delighted to have you here. Prepare to connect with a vibrant community of enthusiasts and enrich your understanding of drones with a wealth of knowledge awaiting you.
Just got my first drone last week.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 2 SE, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum from the beautiful woods of Maine! There’s many knowledgeable members willing to help you with any questions you have. Search the forum using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response! Fly safe and stay safe!
utahloanrelief
