Hello from NOVA
HowSoonIsNow?
Northern Virginia, USA
Hi,
I am a new member from Fairfax, VA. Near Fairfax Circle.
I purchased a DJI Mini 4 Pro, and (obviously didn't do enough research on my area) was surprised to find I cannot even test it out on my own property. Not even a simple 1m takeoff, hover to test it out.
My previous experience has been with an ExtremeFliers drone (kickstarter) that was fun, had a camera attachment, but no advanced features. I lost it in a tree on my property.
Interested to find good areas to fly nearby. I think I can drive a few miles West, and find some areas to explore a bit. Hoping to get familiar so I can use this on mountain bike trips, or family vacations.
Take care!
Welcome from the Hampton Roads area of Virginia, USA.
We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Map…" Check it out and you might find some new flying friends.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in VIrginia, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome. I fly out of both Maryland and Virginia. If you have not done so already, I recommend you download and get familiar with a good app like Air Aware. This will allow you to do "map recon" before planning your trip. Burke Lake Park has some nice views. There is a gravel parking lot off the back side of the golf course that will give you great views of the golf course and Burke Lake.
Hi,
Take care!
If you get your Part 107 you could probably get a LAANC and be able to fly locally with some restrictions. Welcome from North Pole, Alaska
Hi,
Take care!
Welcome from Arizona. Tons of reliable information on this forum....Enjoy!
camposbrito
