Hello from Reynoldsberg Ohio
Hello from the Crossroads of America jdshaw509.
Hello all. New Mavic 3 user Here. Open to any and all advice. Have had several UAVs but not one so high end.
Stay safe!
In case you haven't done it yet, swing by the FAA and register the aircraft.
You should take the TRUST test as well and keep a copy with you when you fly.
Welcome to the Forum. :cool:
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Even in Ohio, there are a couple of Legal Things you may not have done because you had "lesser" drone and may still need to do…
You will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Mini 3 weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…)
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
Since you live in Ohio, there are specific laws and rules for you to follow, please check to ensure these are current.
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
Welcome to the forum! :)
thank you for all the information. I really appreciate it. The Mavic 3 is quite an upgrade from the Fimi that i had
stephy_gl
