Hello, from rural Northwest, Georgia
rob&jo
NW Georgia
Hello, I’m Rob, me and my wife Jo purchased a Mavic 3 Pro about a month ago; our first experience with a drone. We’ve been really enjoying it so far. Just found the forum today and decided to register. I’ve always found a forum on specific subjects to be quite helpful. We look forward to learning from the wisdom an experience of those here
Welcome to the forum! :)
Hello from the Crossroads of America rob&jo.
Nice to meet you Rob & Jo. 🤝
I'm sure you've done it already, but if you haven't, the aircraft needs to be registered with the FAA.
And you need to take the TRUST test and keep a copy with you when you fly.
It's a free no fail test that's easy to take that covers the basics of flying a drone.
Good luck and welcome to the Forum. :cool:
Somebody that appears to be new with these flying birds.
Stay away from Mavic Magnets (🌲).
I good day can can go bad really quick. (Done it) :rolleyes:.
Rod ..
One of the members, @MA2 317 has already advised you on a couple of Legal Things you may need to do… So I will not repeat them here, but please take time to do it, you may be rural, but you have neighbors that may not take kindly to you fly over their property and become Kevins and Karens…
Since you live in Georgia, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic 3 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome man😍
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you have. Search the forum using key words and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response! Fly safe and stay safe!
kholik ibnu
