Hello from the Garden of England
Welcome to the forum! :)
A few useful tips:
  • If you haven't discovered them yet, the DJI manuals and other important downloads are available in the Downloads section of DJI's website.
  • Your drone batteries will last longer if you use and maintain them like this.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
Hi all, New to droning, former aeromodeler and glider pilot here in Maidstone, UK.
A bit ‘goody two shoes’ so I already have my Operator and Flyer IDs plus A2CofC in UK and Europe.
Just looking to enjoy flying my mini 3 pro and its new big brother, Mavic 3 Classic . Skål
Wotcher from about 80 miles north north west. Cheers 'n' beers.
New to droning, . . . Just looking to enjoy flying my mini 3 pro and its new big brother, Mavic 3 Classic
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro and Mavic 3 Classic, including the User Manuals.
After you read the Manuals, read tehm again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
Welcome to the Forum from Sunny Somerset, UK:)
Thank you, while I am already ahead of this curve, I think this is the kind of thing that manufacturers should be persuaded to include with the documentation at sale, even if only as QR code.
I think your advice could include a ‘do not try to do everything at once’ paragraph. Several YouTube videos in the ‘X things you need to know/do … etc’ genre had me tweaking controllers and camera settings but when I came to fly, they became distractions.
Skål, Andy
Reactions: LoudThunder
CMDR DV TEARDROP
