Hello from the UK
Doginabag
UK
Site
youtube.com
Hi everyone. New user here from the south east of England.
Still fairly new to drones, having had my mini 3 pro for a few months now.
I have a good background in photography, but am now getting more into video.
Hope to find a lot of inspiration here, and hopefully some constructive criticism on my own work too.
This is my YouTube channel. :)
Welcome for Alabama, hope you enjoy your drone and he group.
Mike
I reviewed your YouTube Channel, interesting, I am sorry that you had to use the Care Refresh, but aren't you glad you had it? If you search our past postings, you are not alone in losing a drone to a "conflict" with a Geo Zone. One member, also in the UK, flew his drone from an island in Scotland towards another nearby island, only to learn that there was an airport there and "somehow" he busted into the zone, but he could not cross it again to return, his visual flight map, like yours, showed him flying back and forth along the border trying to return. He did panic and later wrote that he had sufficient battery to return to the distance island and land there, but he ultimately also "flew into the sea…"
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
Thank you for the warm welcome.
Yes there were some lessons learned from that incident. Confident now that I can avoid similar happening again, but still get nervous flying over water. Not that it stops me.
Well, you've used your one Fly-Away and if it happens again, you are on your own… Or you can do the "old switcheroo…" One person lost their drone a second time and to get it replaced, they bought a totally smashed up drone of the same model, that they smashed it up even more and removed the identifying serial number and then had it replaced as a crashed and smashed drone that goy driven over…
Or you can buy a set of pontoons and you might be able to recover it as it floats past the "White Cliff of Dover…" L 😂 L . . .
Jeshirley_Koi
