Hello from Wasaga Beach.
Rosypilot
Wasaga Beach , ON
Hello all. From Wasaga Beach,ON, CDA. Found this forum by browsing since I had a problem with my Mavic Mini, frozen screen. May have the problem rectified, found that the last update I thought I had loaded hadn't. Seems to be working now. New to flying, although had mini for over year had not been using it that much. Impressed with the looks and content of this forum.
Greetings from Birmingham Alabama, welcome to the forum!
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Happy, Safe and Legal Droning…
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum! :)
Ohhh that is a beautiful area Wasaga. I’m from the states but visited there where my family is in Toronto.
Reactions: Steel63 and GFields
djimini3
