Hello from Woodstock GA
Also, take time to read our Community Guidelines. If you plan to promote items/services for sale, you must become an approved vendor.
Welcome to the forum! :)
I just bought a drone and received my TRUST certification.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
Good, you started off right and have your TRUST Certificate.
Now, if your Drone weighs less than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Georgia, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
For my 1st 'outdoor' drone flight I chose a baseball diamond early am. Launched in the outfield just
a couple of feet from 2nd base. That gave me plenty of elbow room to practice basic maneuvers.
Here's a link to a FREE course for beginners, from Pilot Institute. Have fun, fly safe.
Link: Recreational Flying Made Easy - Pilot Institute
Welcome to the forum from the beautiful woods of Maine!
I’d look for baseball or football fields that are usually out in the open and you can practice to build up your confidence. Fly safe and stay safe!
DigitalJoe
