Hello & Good Morning!
Received my DJI Air 3 yesterday.
You've done Good!, Got your TRUST and registered your drone, as you wrote you only need to learn to fly it…
Since you live in New Jersey, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air 3.
After you read all the material, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
Thanks for the advice. Been watching the tutorial videos and decided to a test flight. Took off, hovered in place. Got used to the control and the controllers. Then did a couple of more easy test flights and it is so easy to fly. Decided to go to 200’. Was a little nervous but amazed at the image clarity on the RC2 screen. On my last flight, I went to 398’. Sharing a picture I took. IMG_3458.png
@BrickAir
OMG, is this first time you flew something over your head without out a string?
I wasn't very good with that, there was no RTH :)
Almost forgot.
Welcome to the forum!
Rod ..
@BrickAir
Your stating this is first time you flew something in the air with a remote control?
Really?
If so are you a Gamer?
If not OMG!!
Rod ..
@Prop Wash
I really space out on thanking the military.
Took my best buddy to the Portland Airport 1981 when he went in to the army.
His younger brother went into the Navy.
Still have contact with both.
My issue is our government is not taking care of these guys
Yeah it turns into politics
I think this a cool picture, guy in the middle is the younger brother.
I would assume most of us would recognize one of the other two.
Its not my thread I won't reply to this post unless it is OP.
Rod ..
Reactions: BrickAir
@BrickAir
Really?
If not OMG!!
Rod ..
Nope. Not a gamer. I’ve played GTA on the PS5 but that’s about it. Always wanted a RC helicopter. So I decided to go down this road. It was pretty easy to get the feel for this. Watched the tutorial videos and followed them.
Thanks for the advice. Been watching the tutorial videos and decided to a test flight. Took off, hovered in place. Got used to the control and the controllers. Then did a couple of more easy test flights and it is so easy to fly. Decided to go to 200’. Was a little nervous but amazed at the image clarity on the RC2 screen. On my last flight, I went to 398’. Sharing a picture I took. View attachment 176349
I think you are moving too fast, you are probably flying it using only the video feed, you need to learn to fly the drone strictly by sight, flying away from you and flying toward you, by eye only, no video…
It takes time to get comfortable to the controls and you cannot do that in one day…
  • Love
Reactions: RodPad and BrickAir
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you may have. Search the forum using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response!
A word of advice, find a football field or another wide open field and practice, practice, practice! Fly safe and stay safe!
I can do you eight better… That's me in the center (c 1988) and I'll let you guess who they are:
a. My Ex-Wives having a Reunion…
b. My Softball Team…
c. The Dallas Cheerleaders…
d. A Tupperware Party…
If it’s not obvious by the Go-Go Boots, it's "C" the Dallas Cheerleaders. I got to take a week off and since I had a military license to drive a 50-passenger bus, I got to drive them all over South Korea to all their Shows…
Oh, the sacrifices I make for my country…
Maybe. But I kept it in sight the whole time. Keep looking at the screen, then the drone, back to the screen, back to the drone.... I do have to learn more and gain more experience.
cbooth
