I'm from Canada and started using my
Mavic Air 2 not long ago
mavicpilots.com
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
drone-laws.com
Since yu wrote that you, "started using my
Mavic Air 2 not long ago", here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mavic Air 2, including the User Manual.
Learn and download
Mavic Air 2 related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
