Hello Pilots! From sunny (gloomy) Illinois!
Hello all! Just wanted to say hi to the board! So glad to see something like this out there. Just got an Air 2s
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
One of our members MA2 317 has already given you the heads up on how to stay legal, but it doesn't' hurt to remind you again, I know how excitement you are…
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Illinois, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Happy, Safe and Legal Droning…
amusser86
