Hello!
Hello from the Crossroads of America keri004
Welcome to the Forum. 😎
I own a Mavic 2 Pro. Here to learn as much as possible.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Georgia, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic 2 Pro/Zoom, including the User Manual.
Fly On and Fly Safe…
Hi, Keri!
Welcome to our forum! I fly a MP2 as well, and I love it! Lots of fellow Georgians among our membership, as well as some VERY experienced droners to help you grow as a pilot and photographer. Be sure to check out the many videos and tips.
Glad to have you aboard!
Rich R (aka Hauptmann) from North Texas
Welcome to the forum! :)
JefScot
